It is currently Fri Aug 22, 2025 1:15 am
PostPosted: Tue Aug 20, 2013 2:18 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I have a couple of 1/4" presanded ebony fingerboards from LMI that have seemed to warp quite a bit in storage... I noticed it when I received it so I stickered and stacked it, and it's even more warped now. Is there anything I can do to restore it or is it a lost cause?
Typhoon Guitars
PostPosted: Tue Aug 20, 2013 2:23 pm
I had the same on one board, and I decided to slice it into bindings for other ebony fingerboards, headstocks...
Or, you can make it flat again with a vacuum press and a router, but the result will be a fingerboard not thick enough...
PostPosted: Tue Aug 20, 2013 2:27 pm
Last Name: Cox
That's why I don't like Ebony....
I have an ebony fingerboard blank.. Beautiful, perfect black.. No smudges, white, anything....
Twice a year - Spring and Fall... The end of the blank warps into a crooked, funny shape that looks like an old arthritic finger.... and then it settles down again.....
No way I can use it on a guitar....
I would contact LMI....
PostPosted: Tue Aug 20, 2013 8:35 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I bought it a long time ago... doubt LMI would do anything about it.
Typhoon Guitars
PostPosted: Wed Aug 21, 2013 5:25 am
I have done this. It involves heat, so you cannot do it if there is wax on the wood.
Get some steel plates bigger than the board. Soak the board (maybe optional). Clamp the board between the plates with old fashioned steel C-clamps. Put it in the oven and bake it for a couple of hours. I think 300 would do. Turn off the oven and let it cool over night.
Down side is the heat will accelerate rust on the clamps.
PostPosted: Wed Aug 21, 2013 12:17 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
lightly wet the concave side of the boards.
clamp to a very stiff & flat surface.
let dry for a few days.
the longer the better.
Make sure the convex side is open to fresh air.
This may not make it completely straight.
slice the fret slots if ya can!
This will help release the stress in the board.
I hope this helps you!
Mike ;)
Mike Collins
PostPosted: Wed Aug 21, 2013 12:50 pm
First name: Ringo
If you follow this advice keep in mind that it can make the wood more brittle, and ebony is already quite brittle, so you'll want to take extra precautions against chipout.
